Stats
Baldrick17 Web Interface Stats
The Stats board gives you a heads up as to what's going on with your controller
Uptime​
Frame Rate​
This lets you know what the FPS (Frames Per Second) the controller is currently outputting (The Baldrick8 has been optimised to output 750 pixels per port at 40fps
Streaming State​
Will indicate if the board is receiving data from a specific IP address and what type of data. The board will also show if two IPs are streaming to the board at the same time which is very useful for debugging those pesky problems
Network Throughput​
Like the FPS, this gives you an indication of the volume of network traffic passing through the controller, this should help with debugging
Temperature​
With a sensor next to the Ethernet connector, this gives you an indication of the board temperature (in Celsius) because water freezes at 0, not 32.. how does that make sense?
Generally, PCBs and components are good for -40 to +85°C, Anything below 60°C on this board is fine and nothing to worry about. If the temp is above that, try blowing on it like you would a hot chip out of the oven.
Firmware Version​
We regularly release new firmware updates with features (and sometimes people break our boards and we have to fix it) (clicking the new version will upgrade it in place then restart the controller)
IP Address​
