Connecting Pixels
It's time to connect the lights.
To pigtail or not to pigtail
We recommend adding pigtails to your controller rather than pixels directly.
Your controller will come with 3 port Phoenix connectors
The Phoenix Connector Explained
- GROUND - The negative wire of your pixels (this is BLACK)
- DATA - The data in wire of your pixels, (this is YELLOW)
- LIVE - The positive wire of your pixels (this is RED)
(The colour suggestions are for BALS pixels, if you are buying from somebody else... then ask them)
