xLights Connection
You can connect directly with xLights, look for Baldrick Controller under ilightthat
You can either;
- Click Discover and xLights will automagically find the Baldrick8.
- Add the board manually by selecting ILightThat as a vendor and Baldrick 8 Port v1 as the Model. You will then need to put the IP Address in manually
